slotted crankshaft nut?
Old Jan 11, 2002 | 08:34 PM
bermbanger400's Avatar
how on earth do u get this off? i know its left handed thread.but how do you get it broke loose when i try the hole shaft spins.
any hints or tricks guys?
Old Jan 12, 2002 | 11:29 AM
RickRitter's Avatar
Polaris makes a special socket for removing that nut , I believe it sells for close to $75 . (Correct me if I am wrong , I bought mine a long time ago )
You are correct about the threading it is left handed.
Old Jan 14, 2002 | 10:57 AM
ScramblerX's Avatar
Berm,
I have explained this 2 times to you. Do you ever look at the messages you post? You have written about 4 post on the same topic.
Old Jan 14, 2002 | 06:22 PM
yes i read them! and by the way this is only the 2nd post ive made about this. first one about the slotted nut Scramblerx!if you dont like what i ask about then dont read them.
Old Jan 15, 2002 | 03:22 PM
ScramblerX's Avatar
answer on 1-2-02
answer on 1-7-02
You will need to use a "piston stop" to stop the shaft from spinning, it threads into the spark plug hole.
Old Jan 16, 2002 | 03:02 AM
Charlie's Avatar
Use a large punch and a hammer to get it off and on. The special tool is nice if you afford it but in a pinch a punch will work. A couple of good hard hits normally breaks it free.
Old Jan 16, 2002 | 12:49 PM
ScramblerX's Avatar
How many hits should he take to torque it to 45 ft. lbs?
Old Jan 18, 2002 | 09:24 AM
ProXScrambler's Avatar
You can also go to just about any Polaris Master Mechanic and they will usually either do it for you or let you do it right there, or let you use the tool. That's what I did. If you are going to replace the seals (which is a good idea if you are breaking the block apart), use a torch to heat it up a little, comes right off. Good luck, let me know if you need any help on the motor, had mine apart twice! (1995 Scrambler 4x4)
jgiljr
Aug 21, 2015 06:15 AM
ghost civic
Jul 30, 2015 04:09 PM
clsharky
Jul 13, 2015 02:07 PM
fourlix
Jun 15, 2001 12:14 AM
ScoobyDFW
Jan 8, 2001 12:25 AM
