slotted crankshaft nut?
answer on 1-2-02
answer on 1-7-02
You will need to use a "piston stop" to stop the shaft from spinning, it threads into the spark plug hole.
answer on 1-7-02
You can also go to just about any Polaris Master Mechanic and they will usually either do it for you or let you do it right there, or let you use the tool. That's what I did. If you are going to replace the seals (which is a good idea if you are breaking the block apart), use a torch to heat it up a little, comes right off. Good luck, let me know if you need any help on the motor, had mine apart twice! (1995 Scrambler 4x4)
400, atv, atvconnection, crackstaft, crankshaft, nut, polaris, remove, scrambler, size, sloted, slotted, socket, sockets, special
