250R wire harness ?
Old Jan 11, 2002 | 09:53 PM
jmoney45's Avatar
Anyone know if an 86 ATC 250R wiring harness will work on an 87 TRX 250R?
Thanks.
Old Jan 11, 2002 | 10:03 PM
HondaMan85's Avatar
I would imagine that it would, cause the 86 atc and trx are the exact same, and the only changes were made to the chasis, piston, and rod between the years of the trx's.
Old Jan 12, 2002 | 01:59 PM
Dill's Avatar
it would probably work, if you could get everything to line up properly, which I somewhat doubt.
Old Jan 12, 2002 | 10:14 PM
Schoebs's Avatar
I would tend to doubt it, as the harness for an 86, 87, 88, and 89 TRX are all slightly different.
Old Jan 14, 2002 | 12:14 PM
retro's Avatar
It will work with some modifications. I think the ATC harness is grounded at the rear of the frame while the TRX harness is near the top left radiator mount.
I did the same with my 86 ATC harness on my 87 TRX.
ERIC
Old Jan 14, 2002 | 07:50 PM
jmoney45's Avatar
So all I would have to do is find someplace near the rear of the frame to hook the ground to?
Old Jan 15, 2002 | 09:57 AM
retro's Avatar
If you can find a bolt at the rear of the frame to ground the harness do it. I just cut off the green wire and reconnected near the front.
ERIC
Old Jan 15, 2002 | 10:24 AM
LT80's Avatar
LT80 Expert
the diff years of stators have different plugs on them,that will be the problem most likely [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 17, 2002 | 11:57 AM
DirtDiggler's Avatar
Hey Jmoney45 what's up? You picked up a trx250r? Very cool man is it in really bad shape or not. The kid in Avon that owns Avon Cycle Joint is kind of this areas 250r expert. He has 3 of them he races and he usually picks one up here and there if he likes it or thinks he can sell it. I've seen him race at our local mx tracks and he never seems to loose. He races in our local pro class and generally wins by a mile. If you want to check out his shop and talk to him just get a hold of me or Heath. I can't think of anyone in our general area that would no more about 250r's than Aron. How far away from being able to ride the 250r are you?
Old Jan 17, 2002 | 06:44 PM
jmoney45's Avatar
DirtDiggler,
I am actually picking up parts here and there to build one. I bought a frame, a-arms, and most of the front end components as well as a swingarm. Everything is in excellent condition. I will need to get some more misc. parts, the motor, tires, and the plastic. I am hoping to have it going this summer but the house has to come before the motor (so the wife says). I have been waiting for a little cold weather and some snow to ride in but have been disappointed so far. Maybe this weekend. We'll have to get together again. Have you decided on a new machine yet?
