Methanol Carbs???
Old Jan 14, 2002 | 08:12 PM
Orlando's Avatar
Quick question. Are methanol carbs the same as regular carbs with a different jetting or a re they really different? What would be needed to convert a methanol carb to regular gas or vice versa.
Orlando
Old Jan 15, 2002 | 02:23 AM
raptor720's Avatar
Alky carbs "usually" have the float bowls enlarged, one float removed, bigger needle and seat, a power jet added, a special taper on the jet needle, etc. So, they are fairly different to a degree.
Old Jan 15, 2002 | 08:23 AM
LiveWire's Avatar
I was thinking it might be possible to convert a gas one to methanol by installing dual Dial-A-Jets as opposed to a carb that has a power jet and besides the other changes. A dual system provides 20-30% of the fuel. Combined with jetting up, it should be able to provide enough fuel.
Another cool concept with the Dial-A-Jet is to add another float and bowl that is attached to a plate of aluminum. The carb runs off gas and the second fuel bowl is connected to a small alcohol tank. The Dial-A-Jet(s) is fed from the alcohol bowl. You can cruise around on gas, but the alcohol gets added when getting on it hard. Idle for a bit and the alcohol will clear out of the engine. A picture of this.
Old Jan 15, 2002 | 08:35 AM
Dill's Avatar
Mikuni TM's are easily convertable back and forth. Change out the pilot, passageway, mainjet, needle, and turn on/off the powerjet, and you can go between gas and alky. MP Racing and FTZ sell such carbs.
Old Jan 24, 2002 | 07:27 AM
AnchorDive's Avatar
Once "converted" to alcohol, could you then introduce percentages of Nitromethane? I used to race RC airplanes (200+ mph) and would normally run 45% Nitro. Any thoughts?
Andrew
Old Jan 24, 2002 | 09:52 AM
Backcountry's Avatar
There a few people who have figured out nitro in 2 stroke motors. Its doable for sure, but requires some excellent tuning skills, and some decent amount of pistons to get it dialed right it seems. The benefits from such are pretty nifty...PPO, propalyne oxide, is another oxygenate that can be added to methanol and is a tad tamer than nitro.
Old Jan 31, 2002 | 08:32 PM
the500bansheepilot's Avatar
Hey live wire are you fimiliar with lectrons. If you are I was wondering if you could run the alcohol with the power jets for a 2nd fuel source
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
