1999 Yamaha 350 Big Bear valve noise
Old Jan 15, 2002 | 04:42 PM
Blasto's Avatar
I have a 99 Yamaha Big Bear 350 4X4. Despite adjusting the valves to factory specs I still get an usual valve noise. It actually sounds like the vales are echoing (slapping/pinging) within the upper portion of the engine.The noise is definately coming from the inspection plates covering the valve area. This happens especially when the motor heats up. There is no performance problem that I can tell but the noise has me concerned. The dealer told me 99 Big Bears are noisy but of course they want $200.00 to check it out. Should I be as concerned as I am. Any information would be appreciated
Old Jan 15, 2002 | 05:45 PM
DaveC's Avatar
$200.00!! ouch, I can get my quad fully serviced for $110.00 that includes motor oil change, front and rear diff. oil change air filter cleaning, spark plug and VALVE ADJUSTMENT.
Maybe the $200.00 was to do more than adjust the valves, but what more could be done? You would think they could replace the valves for $200.00.
Old Jan 27, 2002 | 09:58 PM
klown's Avatar
well guys....it looks like you both are getting the shaft on that deal...i can get my valves set, rear and front gear box oil changed, and motor oil with oil filter and spark plug for the great price of just $40...down here at RSE Racing in Vinton Louisiana.
Old Feb 4, 2002 | 08:33 PM
raktrakr's Avatar
my grizz does the same thing,its not loud but its noticable.since its winter im assuming your running the thinner oil? if you are that could be it
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
D-Hagz
Jul 4, 2015 02:19 AM
