Nick wants more power for his 250x!!
Old Feb 9, 2000 | 05:44 PM
NC250x's Avatar
I want more power and speed for my 87 Honda 250x. It is mostly stock except for K&N filter and RCM Straight pipe which I don't even run cause its too loud for me. I don't want to spend a whole lot of money. Anyone PLEASE HELP!!!
Old Feb 9, 2000 | 09:59 PM
PamFalcioni's Avatar
Nick,
Depends on how far into the engine you want to get, but if you still have the stock muffler, you can get a larger headpipe & run the stock muffler and get the same performance increase (or better) than you have with the RCM system. Powroll sells headers that fit your stock muffler ($100).
After that, I'd go with a vented airbox lid ($50), as long as you're not using the thing as a submarine!
If you're willing to get into the engine, you can add a mild camshaft (about $130), and maybe a slightly larger piston kit ($100-$200).
If you do all this, you'll end up with about 20 - 25% more hp.
Old Feb 10, 2000 | 10:54 AM
Exer_95's Avatar
Pam...
That is a very intesting idea !! New header pipe w/stock muffler !! You said this will give you as much or more then the RCM set-up !! What about vs. FMF or SuperTrapp ?? How does this compare !! I would also like more performance, but don't want to get to loud ! I have a 300ex.
Thanks
Old Feb 12, 2000 | 02:20 AM
a250xrider's Avatar
I have an 87 X also. I did a pocket porting job on mine by just deburring the intake and exhaust ports and cleaning up the area under the valves. I then put a Wiseco 12.5 75.5mm piston in and rejetted the stock carb. I don't run an air box lid and I still have the stock exhaust to keep things quiet.
Its not the fastest X around, but it holds it own a whole lot better than it ever did before. I ride with other Xs and mine seems to have more top end power. I'm going with the cam, exhaust, and carb next.
Old Feb 12, 2000 | 02:21 AM
a250xrider's Avatar
MeadowlarkFarm
Nov 27, 2019 08:40 PM
nick c
Sep 13, 2015 10:08 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
