Fuel injection and cold weather
Old Jan 17, 2002 | 07:09 PM
Ronnnnn's Avatar
Will the fuel injection compensate automatically for riding in 90 plus degree's to zero degree's without any extra tuning?
Old Jan 17, 2002 | 11:38 PM
SparkyEX's Avatar
There is a cold weather map that must be downloaded for the new computer. If you buy a new one then the dealer should already have done it. I have the older model computer and have no problems starting in cold weather. I use no gas, if it doesn't turn over after 4 cranks, I stop, hit the stop button, then try again. Usually starts on first try, never more than 3.
Old Jan 17, 2002 | 11:40 PM
YoDaddy's Avatar
As far as I know, the only time you really have to adjust it is when there is a big change in air intake or exhaust. One of the fuel lines on my Dale was shut off and it sputterred a little at the bottom end and still pulled hard in top end, while in most other quads, just a little fuel restriction would cause it to barely start, and barely pull. I fixed the problem immediatly but I could tell that it would compensate for the change in fuel flow a lot.
Old Jan 18, 2002 | 06:35 PM
ScoobyDFW's Avatar
I thought I read of a company making a hand held programmer for use in the field for tweaking the EFI
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Brandon400
Sep 7, 2015 12:20 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Pahuntman
Sep 5, 2015 11:07 AM
Sep 1, 2015 01:45 AM
