new guy could use some advice
Old Jan 17, 2002 | 10:06 PM
LJM's Avatar
LJM
Hi im new to the forum and the sport. I just purchased a 02 scrambler 500 4x4 and a 01 scrambler 90 for my son so far the big one has been great but i have only 3 to 4 hours on it , but ive been smiling the whole time. Could someone tell me about getting a little more bottom end snap out of it? I know its not a two stroke screamer, and im not interested in going as fast as i can just some more umpth off the line. Any help would be greatly accepted.
Old Jan 17, 2002 | 10:18 PM
Ronnnnn's Avatar
clutch kit, call HPD or RCR tell them what you want and you will have it, after you part with a little green.
Old Jan 17, 2002 | 11:13 PM
ftwflh's Avatar
All you need is a differant primary spring Try a white,green or purple.All of these will make it quicker white is little hotter then green then purple.
Old Jan 18, 2002 | 01:43 AM
Scaryfast's Avatar
LJM, Have you changed your secondary clutch spring position? There should be 3 numbered holes in one half of the clutch and 2 in the other, giving you several different combinations. I don't understand all aspects of setting up polaris clutches, but I changed the settings on my 01 scrambler 500 until I found the one I liked. At the stock position that mine came in , it would hook up at low rpm. At my current setting it builds higher rpm before engagement therefore it seems to "jump naked" out of the hole. I did'nt time it before the change so I don't know if it is actually any faster, but I do know the front end won't stay on the ground now!!! I would suggest talking to some of the other people on here that know clutches and have the facts. You might be looking for more of a performance boost than this will provide ,,,,, but this ones FREE![img]i/expressions/face-icon-small-wink.gif[/img] my pics
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
