250r engine assembly ---NEED HELP!
Old Jan 22, 2002 | 11:58 PM
Addictedtomud's Avatar
I am putting together my 250r motor, but I cant get the crank to seat into the main bearing (left case half). Clymer manual says to take it to a Honda dealer and have it done w/special tools! Is that really necessary? Lots of people work on these motors and I can't imagine that everyone has to take it to the dealer for this....PLEASE HELP!!!
-Addict
Old Jan 23, 2002 | 01:48 AM
Dill's Avatar
heat the case at about 200 degrees in an oven. put the crank in the freezer for about an hour. get the case nice and warm, and the crank cold, and try it again
Old Jan 23, 2002 | 09:29 PM
Need4Speed's Avatar
I've never had to heat them but remember buddy that the case will be hot and will burn the $hit out of bare hands. I usually keep the crank in the freezer overnight. But the results are all the same in the end.
Old Jan 23, 2002 | 10:04 PM
HondaMan85's Avatar
Make sure your bearings are lined up and seated properly. I had that problem when i was installing the transmission, cause a bearing wasn't all the way seated.
Old Jan 24, 2002 | 01:38 AM
Thanks for the tips. I will try freezing the crank first. If that doesn't work I will also try to heat the case. I bought a set of brand new Honda cases with all new bearings already installed. The seals are also installed, so I am afraid heating them up will ruin them...
-Addict
Old Jan 24, 2002 | 11:57 AM
Dill's Avatar
200 degrees won't hurt them a bit.
Old Jan 24, 2002 | 10:37 PM
seanl's Avatar
should you do the heat/cold thing with the seals? any other tips? thanks,
Sean
Old Jan 24, 2002 | 10:55 PM
IT WORKED!!!
Crank in freezer for an hour.
Case in oven at 200 for 5-7 minutes.
Wife thinks I am a freak.
But my bottom end is now together!
THANKS
-Addict
PS - 200 degrees did not appear to hurt the seals...
Old Jun 24, 2003 | 04:17 PM
Screaming250r's Avatar
Default 250r engine assembly ---NEED HELP!
-Addict
How much did that cost from Honda? I have to crack my case and I am wondering if it would be cheaper just to buy the set up like yours where it is already apart........
Old Jun 24, 2003 | 06:31 PM
250R4LIFE's Avatar
Be sure to put that in your wives cookbook....[img]i/expressions/face-icon-small-cool.gif[/img]
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
