I need some help with a Kawasaki Bayou 300.
Cody, your front tire sidewall displays "24X8-11," your rear shoes say, "24X10-ll," meaning tires nominally 24" in diameter, with tread widths nominally 8" and 10" wide, respectively, mount on rims 11" in diameter.
If you're satisfied with your old tires' performance, buy the same size again. If you want bigger, more aggressive tires, buy 'em. The main contolling number for you, if you want to use your factory rims, is "ll," their diameter in inches. Bayous have lots of clearance for oversize tires if you go that route.
Tree Farmer
Tree Farmer
now do you want to replace the tyres with stock tyres get dunlop KT962A from your local dealer,if you want to replace the tyres with somethin that'll get you more traction, go with titan 489's they make the exact same size as you currently have.Look through an ATV magazine(such as dirt wheels) to find the tyres.
