Stock Mojave Rev Limit
Old Jan 24, 2002 | 09:35 PM
Kawi250's Avatar
I just ordered a tach from summit racing and it reads up to 8,000 RpM's. I was wondering what the stock rev limiter is set for? Also, what is a good range to set the shift light? Thanks guys!
Old Jan 24, 2002 | 10:01 PM
mentalmojave's Avatar
Well you should of ordered a bigger tach because the mojave revs 10500rpm when the rev-limiter comes on. It will rev even more with some cams and the rev-limiter out,probaly around 11000rpm.
Old Jan 25, 2002 | 07:50 AM
Kawi250's Avatar
Oh well. LoL. If I find that I am shifting beyond 8000 RpM's then I guess I will order a bigger tach. Thanks for the info though.
Old Jan 25, 2002 | 10:45 AM
mojaveman1's Avatar
Hey can you put that on a single cylinder almost every tach that i no of is four anywhere from a 4 to an eight cylinder
and how r you gonna mount that
Old Jan 26, 2002 | 01:03 AM
Kawi250's Avatar
Well, I am going to run it on 4 cylinder mode and it should work that way. Alright, on a 4 cylinder engine, two pulses are sent to the coil every one revolution. On my quad, every one revolution of the engine there are two pulses,(Or so I was told) so therefore I THINK it will work. And for the mounting, I am goin to make a bracket that goes in between the two bolts of the handlebar clamps. That way I will be able to see the tach when Riding. It should be coming on Wednesday and I'll have it mounted by Thursday if I don't have much to do. I Will tell you guys how it works as soon as I am done.
Old Jan 26, 2002 | 08:55 AM
2000MOJAVE's Avatar
<< Well you should of ordered a bigger tach because the mojave revs 10500rpm when the rev-limiter comes on. It will rev even more with some cams and the rev-limiter out,probaly around 11000rpm >>
I actually think the Mojave's stock rev limiter kicks in right around 8,750rpm. Now with the rev limiter removed or the klr 250 black box and an after market cam and heavy duty valve springs you could probably hit 10,500 rpm's or more.
Old Jan 26, 2002 | 09:56 AM
Kawi250's Avatar
Thanks, it really gives it that much RPM's? I am going for the electric starter soon and then some engine work after that. Will it hurt the motor to rev that much higher??
Old Jan 26, 2002 | 04:48 PM
&quot;The mojaves twin cam quad valved engine rips to 10500rpm&quot; quoted from a hi torque publication. Not sure what issue but I found it on while searching on the internet. Try to find out what issue.
Old Jan 26, 2002 | 07:20 PM
Kawi250's Avatar
Well I put on A Tach, not the one I ordered but another 8,000 RPM one. I didn't rev it past full throttle, because the tach is to my snowmobile and I don't want to blow it. It works fine and is mounted between the handlebars. I can't wait to get the other tach with a shift light and all [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 26, 2002 | 07:56 PM
What rpm did you get on the tach even though you didn't pin it. I know it revs more than 8750 because a warrior revs 8500 and the mojave revs wayyyy more. It has a 58mm stroke so that tells you she revs.
