need tire help
Old Jan 28, 2002 | 09:59 PM
rapdaddy's Avatar
MY factory tires are 20x10-9.I know the 20 is highth ,but is the 10 or 9 the rim hingth. can I go to a 22x12-9 as long as I keep the 9 or do i have to keep the 10.
HOW does the pure sport realter a/t do on trails and sand? can it be used for both?
Old Jan 28, 2002 | 10:48 PM
FISHER1648's Avatar
See www.yamaharaptor.com for a good explanation on tire sizing in the tech tips section.
Old Jan 30, 2002 | 09:29 PM
rapdaddy's Avatar
can any one help me with this.
Old Jan 31, 2002 | 09:19 AM
CBUS660R's Avatar
How to read tire sizes. The first 2 numbers are tire height and width and the third number is rim diameter. Stock tires are 20" tall x 10" wide on a 9" diameter rim. A 22x12-9 tire will fit on your stock rim. If you put 22" tires on, you should drop your front sprocket size one tooth (from a 13 to a 12).
Old Jan 31, 2002 | 04:30 PM
SR2's Avatar
SR2
CBUS660R whats the reason for changing the sprocket? Is it nessasary if i put a 20x11x8 on my blaster? thanks.
Old Jan 31, 2002 | 05:22 PM
CBUS660R's Avatar
When you increase the tire height, you are changing the final gearing. In this case, a 2" increase in tire height is a 10% increase, by dropping the front sprocket from a 13 tooth to a 12 tooth, you decrease the final gearing by about 8% so that the final gearing remains close to stock. As for your Blaster, I am not sure what your stock tire size is so I can't say if a 20" tire will change your gearing.
Old Jan 31, 2002 | 05:29 PM
crazyhorse03's Avatar
ya go with the 9 in rim. by the size of the tire you picked im assuming you ride woods so i would recommend the holeshot xct's.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 31, 2002 | 06:34 PM
RaptorWarr's Avatar
Yea, I went with the 22" xct's and they work great! Although, in addition to the 12 tooth on the front I went to a 42 on the rear before it felt right.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
