oFFsEt RimS
I plan on buying a set of holeshots for my raptor, sizes 19x6x10MX and 18x11x8MX. Will the rear width be wider since the tires are 1 inch wider than stock ? If not who offers offset rims that would widen the front and rear ? I already have a LSR axle but i want wider, front and back. a-arms are still stock for now. thanx
those are some pretty small tires, most rims offered at least for the front tend to be offset, I have 1" and 2" offset douglas rims (in the front, not sure about the offset in the back), I did not like the 2" offset, I felt it left by brakes overly exposed, best thing is to check when ordering your rims. you can also add spacers both front and back if you need more width
If your tires are 1" Wider than stock and you are using the stock rims here is you new track width.
If you put the new tire up behind the stock tire and center them you will see theres and additional 1/2 inch on the inside and an additional 1/2 on the outside. With this in mind you will gain a total of 1" on the entire track width. Adding the 1/2"s gained on the outside of each wheel.
badgerboy1
Sep 26, 2017 06:11 PM
