Missing Problem
Old Feb 13, 2000 | 09:07 PM
250Thumper's Avatar
My recon's engine is missing. It idles fine, but when I give it throttle it starts sputtering and trying to die. The muffler/silencer thing steams alot after it gets warm like it has water in it, Could it get moisture and not be breathing right? I've changed the spark plug and cleaned the filter, but that didnt help. Could you please tell me whats wrong?
Old Feb 13, 2000 | 09:33 PM
lovinhonda's Avatar
what year is it
Old Feb 13, 2000 | 09:35 PM
lovinhonda's Avatar
what year is it
Old Feb 14, 2000 | 12:31 AM
Tree Farmer's Avatar
Contaminated fuel in the float bowl, such as moisture, can produce the symptoms you describe.
Drain the tank from the reserve petcock position, drain the float bowl with the dump tube or drop the bowl, use known dry, clean fuel, maybe some gas line anti-freeze thrown in for prevention, and see how that works.
When you open the throttle, the carb drinks from the main jet, set low in the float bowl. A quad might idle o.k., drinking from the upper layer of fuel, but when the throttle is opened, it goes flat.
Good luck.
Tree Farmer
Old Feb 14, 2000 | 12:57 PM
drlaney's Avatar
I had the same problem after I sank my Bayou in five feet of water. It would crank and idle but not throttle up smoothly. As Tree Farmer pointed out, the problem was resolved by draining the float bowl. Been running like a sewing machine ever since.
Old Feb 17, 2000 | 01:34 PM
wgr's Avatar
wgr
Check the fuel flow to the carb,if that is not problem check carb for water or plugged jets
skinnyr6
Aug 25, 2023 02:18 AM
Firefighter400
Oct 8, 2022 06:38 PM
Captjay
Jul 23, 2015 12:33 PM
blpersinger
Jul 15, 2015 09:56 PM
steveo612
Jul 11, 2015 08:35 AM
