limited options for oem rancher tires
Old Feb 1, 2002 | 09:02 PM
realtree's Avatar
can anybody tell me why i cannot find a selection of tires to choose from for my 2000 rancher es. there seems to be only 1 or 2 tires of oem size <u>24-8-12</u>(rear) and 24-9-11(front). looking for something more aggresive than the 489;s
Old Feb 2, 2002 | 09:48 AM
hogmaster's Avatar
I am with you there Realtree. I have an 01 ES and I am going to get some 25&quot; 589's. I wish I could find something in that tread type in 24's but It isnt going to happen. From what I hear you will not even feel any loss in power with the 25's. Good luck.
Ryan
Old Feb 2, 2002 | 01:49 PM
realtree's Avatar
how much affect does 25,s have on center of gravity?
I do alot of rock climbing and would rather have the lower center of gravity for stability seems more important than clearance.
Old Feb 3, 2002 | 12:59 AM
Iowahuntr's Avatar
Goodyear Mudrunners come in stock rancher sizes and also I believe Beartrackers do also. I have The mudrunners on mine but went to 12in rims as I had Them available.
Old Feb 3, 2002 | 09:48 AM
redhondarancheres's Avatar
my 2002 rancher has 24x8-12 in front and 25x11-10 in back
The closet i found were dirt devils
25x8-12 front and 25x12-10 back
i'm not sure if they have any that size[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 3, 2002 | 10:47 AM
trailboss450's Avatar
25 Year Member
You are right, there are not many options in 24 inch tires for your rim sizes. If you move up to a 25 inch tall tire I think you will find several more choices. Adding an inch to the diameter of the tire only nets you 1/2 inch higher center of gravity but also 1/2inch of ground clearance. Probably a fair trade off. The other choice you have is to mix tread patterns for front and rear. As long as you keep the diameter (or circumference) of the tires the same it will work fine.
Old Feb 3, 2002 | 02:56 PM
Elrancho's Avatar
When I get sick of the stock rubber I'm planning on 25&quot; mudrunners for my rancher. From what I hear they are really more like 24 1/2's anyhow. I don't have any paticular beef with the stock rubber on the rancher, they've done okay for the 1600 miles I've put on it, curiously it's never gotten stuck in real world conditions, but it got hung on a mud hole at fingure lakes mainly from high centering.
skinnyr6
Aug 25, 2023 02:18 AM
Ramman1
Jun 16, 2016 09:07 PM
Jul 24, 2015 11:57 AM
Scottma518
Jul 16, 2015 09:19 PM
Gtsordo
Jul 13, 2015 10:38 PM
