fmf mega max on my warrior?
Old Feb 2, 2002 | 02:25 AM
warrior620's Avatar
I was wondering if i should put an fmf mega max2 on my 1998 warrior. How much does it help? I am running a pro design filter setup w/ out the lid, 20x11x9 maxxis razrs and a 12 tooth front sprocket wich i am about to change to a 14. I am also going to change the setup of the jet needle to get more mid-ranged power
What would/should my top speed be w/ the correctly jetted mega max w my setup?
I found it for $194.00 to my door
Old Feb 2, 2002 | 10:34 AM
Hurycne's Avatar
That Warrior sounds like the pipe will help it. You can run with the discs but I would only use the quiet core when I had to because it makes the quad run really hot.
Old Feb 2, 2002 | 10:35 AM
Hurycne's Avatar
Did you just get the warrior?
Old Feb 2, 2002 | 04:06 PM
warrior620's Avatar
yes, a traded it for my honda recon about 2 weeks ago
Old Feb 2, 2002 | 04:07 PM
warrior620's Avatar
i appreciate your advice
THANK YOU
Old Feb 3, 2002 | 08:34 PM
warrior620's Avatar
any other advice? Anything would be helpfull.
Old Feb 4, 2002 | 12:04 AM
Blaster96's Avatar
The FMF is not as well built and tuned as the white brothers. Yes the WB is more $$$ but you get the bang/buck.
Old Feb 4, 2002 | 01:24 AM
warrior620's Avatar
thank you i know that the white bro. is a better pipe but i am not looking to spend that much right now. I have found a used fmf pipe a few hours ago for about 100 bucks to my door it is in good cond. so i am going to go w/ that prob.
i apreciate your advice
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
