Warrior Camshaft Removal
Old Feb 2, 2002 | 04:06 PM
waynaferd's Avatar
Me and my cousin are currently trying to replace the camshaft in his warrior with one from White Brothers......our problem is we can't get the rocker arm shafts out, and we don't have a manual and the shops are all closed 'till monday. Any help anyone could give would be greatly appreciated......By the way, it's a 2001....Thanks...
Old Feb 2, 2002 | 09:57 PM
Kuntry's Avatar
From what you said all you are replaceing is the cam?
If that is the case then its simple:
1. Put the piston at TDC
2. Remove acces covers for valve adjustments
3. Loosen but don't remove adj. screws
4. Remove cam gear cover
5. Remove cam gear retaining bolt
6. Remove cam gear. ***NOTE use something to hold chain not allowing it to fall into bottom end, I used a coat hanger.
7. Bend locking tabs out of the way and remove two retainer screws.
8. Have a buddy, wife, girlfriend or total stranger hold rocker arms down on to the top of the valves.
10. Slide cam out:-)
11. To reassembly follow task in reverse but add proper torque to all nuts, screws and bolts. VERY VERY important.
Kuntry
00 SP 500
ETC........
Old Feb 3, 2002 | 01:12 PM
waynaferd's Avatar
Hey, thanks alot!! Hopefully we can get this done today so I can get his quad the hell outa my garage!! Thanks again..........Latah.....
QuadRiders
Oct 22, 2015 04:13 PM
clscott84
Sep 21, 2015 10:16 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
