Raptor Pilot jets
Old Feb 3, 2002 | 11:45 PM
URPREY's Avatar
I'm going to be re-jetting my Stock Raptor this weekend. I'm using a K&N Power kit. I have the stock exhaust (for now). What would the benefit be for me to use the 25 pilot jets? I've heard people say they help, but what exactly will they help?
Are the DynoJet instructions pretty close on the jetting? I'm going to install a K&N filter, jet kit, and 4 filtered airbox vents.
Thanks
2001 Yamaha Raptor
Trailtech Speedo, Renthal Bars (Banshee Bend), AC front bumper and rear grab bar, Works Triple Rate front shocks w/ rezzies, K&N Power kit on the way!
Old Feb 4, 2002 | 12:51 AM
THEMOOSE's Avatar
On thier web site (dynojet.com) they say if you need to replace your pilot jet there is something else wrong. They do not recomend changing the pilot jet even with a pipe change. Thier recomendations are usually right on but call them with your specific info. This info is part of what your paying for with the kit so pick thier brains any time you change something.
Old Feb 5, 2002 | 09:30 AM
MichaelAZ's Avatar
I cant speak enough of Dynojet. I called them twice when I was puzzeled and felt like they talked to you, not down to you. Once I called Manny answered and I explained my sons 250ex was jetted exactly per instructions and still was cutting out low end, no prob he says , "I have heard that before, lemme send you a new needle and send the other back AFTER your sure the problem is fixxed" no BS, 2 days later it showed up via UPS. Had a question on drilling my wolerine slide,same thing no prob.
Michael
Old Feb 5, 2002 | 10:52 AM
garyc660R's Avatar
If you have no idle circuit problem....ie backfiring, hesitation, erratic idle and just off idle problems, then the stock pilot is fine with your ride. Since, you will be inside the carbs anyway, a little preventative maintenance with larger pilots can't be a bad decision.
My Raptor blew the carbs off until I wound up with 27.5 pilots and properly tuned mixture screw setings.
Old Feb 6, 2002 | 12:45 AM
scottd's Avatar
I put the #25's in mine at the same time as the Dynojet kit. Glad I did, the stock #22.5's are just too damn lean! Take everyone's work for it.
bmxatv10
Oct 14, 2022 06:23 PM
QuadRiders
Oct 22, 2015 04:13 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
