oil cooler for warrior
Old Feb 4, 2002 | 11:15 AM
YZ250WR's Avatar
Does anyone in here have an oil cooler for their warrior? I was wondering how much of a difference it made, how hard are they to put in and how much do they cost?
thanks
Old Feb 4, 2002 | 01:24 PM
95Warrior's Avatar
I have a oil cooler from Four Stroke Tech. It ran me $107 including postage. There is a thread somewhere where Mickey Dunlap (he owns and runs FST) gives a detailed explaination about the need for the oil cooler kit on the Warrior. Mickey used to race the Warrior nationally. The cooled oil from the FST kit is returned to the engine through the clutch cover and is directly put on the hottest parts of the engine. There is an alternate method of oil cooling the Warrior that involves using parts from the Big Bear. This process involves bringing the cooled oil back in through the oil filter housing. Installation time takes about two to three hours and the only additional tool needed is an 1/8" NPT pipe tap. If I recall correctly (I'll try searching later) the FST oil cooler drops the oil temperature about 50 degrees F.
Old Feb 4, 2002 | 02:15 PM
YZ250WR's Avatar
I know that the cooler oil makes a difference, but how much of a difference does it really make? Do you use synthetics, blend or regular oil?
thanks again
Old Feb 5, 2002 | 02:06 PM
YZ250WR's Avatar
anyone else use an oil cooler on there warrior?
Old Feb 5, 2002 | 11:05 PM
Fendercover's Avatar
i dont have a cooler yet, been having a hard time finding one, i run synthetic oil in all of my machines. by keeping the oil temp down the oil does not breakdown as fast, keeping all of the engine and transmissing parts well lubed. resulting in you not having to change oil before every ride. in cars and trucks i use regular valvoline but in my street bike, birt bike and atvs i use synthetic. they all run at higher rpms and take more abuse. i also change my atv oil about every 3 rides depending on how hard and how long i ride. $30 in oil a year is cheap compared to ruining my ride.
ase certified master auto tech.
ride like there is no tomorrow, one day there wont be
Old Feb 6, 2002 | 08:48 AM
95Warrior's Avatar
Check out www.fourstroketech.com for a phone number to reach them and get an oil ooler. Check under "New Product Release" and there will be a picture of a cooler for a 400EX. The Warrior cooler is the same style, just not as tall. I use either Yamalube or Golden Spectro semi-synthetic. As far as how much difference it makes, I look at it as cheap insurance. A lot of times when i ride at the Silver Lake Dunes during the summer it will be in the upper 80's to lower 90's. On an air cooled motor that's a pretty tough envirement. More heat = less power. Working on my quads because I want to is fun (like installing a oil cooler), working on them because I HAVE to (blown or seized motor) is a drag.
Old Feb 6, 2002 | 09:02 AM
YZ250WR's Avatar
has anyone tried this process? It looks easy enough.
I can get bike radiator pretty cheap, im sure i can get the hose pretty cheap too, all that would cost me would be the kodiak or big bear oil cover and sandwich plate. Is this really doable? check out this site....
http://www.geocities.com/kiwi_craig/COOLER.htm
thanks
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
