110 octane fuel
Old Feb 6, 2002 | 11:20 PM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
I noticed on the underside of my 650 seat that it says 91 octane or higher. The gas station near me doesn't have Premium, they just have 87, 90, and 110 octane. I'm wondering if 110 octane will do any harm or good for my machine? I have just been going to a farther gas station so far, but just wondering.
Thanks
Old Feb 6, 2002 | 11:31 PM
OregonMXracer's Avatar
Just use the 90, if you really want to use the 110, go for it. It won't hurt your engine, and don't be fooled by the "high octane+higher HP" all high octane gas does is help with pre-detonation. Your motor has stock compression probably so the 90 should be fine,
Old Feb 6, 2002 | 11:32 PM
I meant "high octane= high HP"
Old Feb 7, 2002 | 02:19 AM
TrailHog's Avatar
110 octane will make the engine run hotter,if you have a high compression piston you would need to.
Old Feb 7, 2002 | 05:24 PM
Dextreme's Avatar
I have never heard of a high octane gas cause an engine to "run hotter". Usually is it the other way around. The flash point of a lower octane is lower which ignites easier, hence potentially causing more heat. In otherwords your will most likely see your engine temp hotter with 87 than 110.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
