Flatslide Carbs?????
Old Feb 16, 2000 | 10:51 PM
letitsnow's Avatar
What is everyones opinion about using a flatslide carb on an ATV? What are the pro's and con's?
Old Feb 16, 2000 | 11:28 PM
Dune_Scooter's Avatar
I have looked into running larger flat slides on my banshee. The local quad shops HIGHLY recommend them. From what I have been told, the mixture it directed into your intake alot better by the taper on the slide itself. If you look on most round slides, they arent smooth on the bottom near the taper. They have a concaved area that causes the fuel flow to be slowed up due to getting caught in there. They also told me that the flat slides arent as prone to bind in the bore as a round one is. They build alot of alky racers, so I take what they have to say serious. Hope this info helps ya.
Old Feb 17, 2000 | 11:51 AM
brandon's Avatar
I use flatslides exclusively. I have used both mikuni and keihin and they are the best. I pretty much agree witht the previouse post as to why they work better. better throttle response and top end.
Old Feb 17, 2000 | 09:59 PM
sparkys's Avatar
You can also use what are called "UFO'S" on standard round slide Mikuni carbs. It stands for ultimate flow optimizer. They are a plastic insert that fill in the cavity on the bottom of the slide. They claim with them installed the carb has a higher flow rate than a flat slide carb. I installed them on my snowmobile and they really work. You dont have to change your main jets, you do have to drop down to approx.1/2 of your stock pilot size.They can be bought through any snowmobile shop. They are made by a company called Thunder Products.
Old Feb 22, 2000 | 07:55 PM
THREEX2's Avatar
I ALSO USE THE UFO'S ON MY SNOWMOBILE. MUCH CHEAPER THEN FLATSLIDE CARBS AND JUST AS AFFECTIVE. ON TESTS THEY FLOW MORE FUEL AT 1/4 TO 3/4 THROTTLE THEN THE FLATSLIDE CARBS. HERE'S THE # 1-320-597-2700. www.thunderproducts.com
THEY CAN ONLY BE USED ON MIKUNI CARBS. PUT A MIKUNI 34mm CARB ON MY '84 ATC 250R, HAVE THE UFO FOR IT JUST HAVE TO INSTALL. WILL LET YOU KNOW WHAT A DIFFERENCE IT MAKES. MADE A BIG DIFFERENCE ON MY SLED.
Old Feb 22, 2000 | 08:12 PM
letitsnow's Avatar
The guy who invented UFO's and sells them lives about 10 miles from me..I'm wondering if flatslide carbs are much better than roundslide, or not.
Old Feb 23, 2000 | 10:23 AM
THREEX2's Avatar
THEY DO FLOW A LOT BETTER THEN THE ROUNDSLIDE CARBS, BUT IF YOUR NOT LOOKING TO SPEND A LOT OF $$$$ UFO'S ARE MUCH CHEAPER AND FLOW BETTER THEN FLATSLIDE, EXCEPT FOR WIDE OPEN THROTTLE.
Old Feb 23, 2000 | 09:16 PM
Johnnnn__H's Avatar
I am considering getting a flatslide for my warrior, mikuni makes one with an accelerator pump, kind of pricy, but should be the ultimate in throtle response for a four stroke. The flatslides have inserts in them, jet blocks I think they are called, on each side of the slide, witch makes the ID. smooth, and throtle response is suposed to be better. I think the round slides were there first design and the flatslide was an improved design.
Old Feb 24, 2000 | 07:53 PM
letitsnow's Avatar
Thanx for the info.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
