400L piston ? NEED HELP
Old Feb 18, 2002 | 03:24 AM
TXredneck's Avatar
1996 400xsplorer
Do u guys know if they make a high comp.for my 400? If so who makes it,and how much?
I have my motor out right now to put new rings or a new piston in.And there seams to be some slack in the crankshaft,is it that hard to chang out the bearing?I plan to enstall new a pipe, jet kit,clutch kit,K&Nfilter,reeds,shock and struts,shorter handle bars,stering bushing,waterpump seals,start kit,and battery.While I have my motor out any ideas ya'll can come up with to keep her dependable and improve proformance would help.
Thanks
Old Feb 18, 2002 | 04:48 AM
kukerdan's Avatar
everybody says there is no high comp, piston for the 400, but i have one, it runs best on cam II racing fuel from texaco, but i usally keep it on 93 oct.
Old Feb 20, 2002 | 02:50 AM
TXredneck's Avatar
Any body with some ideas speek up,please!!!!!!
Old Feb 20, 2002 | 03:42 PM
Jack's Avatar
I believe you need to have head work done to raise the pressures. A piston alone, won't do it. Call Rick Ritter, he can help you out.
Old Feb 20, 2002 | 06:00 PM
AZ400L's Avatar
I have never heard fo a high compression 2-Stroke piston, that inof itself will raise compression. Their are pistons available that are designed to work better in high compression 2-Stroke motors, IE Wiseco Forged, which is what I believe Kukerdan may in fact have.
Raising a motors compression is the easiest/cheapest route to HP. With the motor off I suggest you have the head shaved slightly (.020) by a reputable shop such as RCR or HPD.
Combine the head work with the mods you intend to get and it should wake the 400 up a bit. Also, spend the extra $ and get a new piston and have the jug honed or bored if neeeded! OE 400 pistons do not work well after a re-ring. It would be a shame to over look that adn ahve to tear ti all apart again in a month.
Old Apr 26, 2003 | 08:22 AM
paulywally's Avatar
Default 400L piston ? NEED HELP
Talk to the HOTSEAT guys, they have lots of bolt on HP products for your 2 stroke
Old Apr 26, 2003 | 09:15 AM
NCScrambler's Avatar
Aaen is a good route also, go with a Wiseco piston and get the head shaved for higher compression. The factory piston will not hold up to mods for long.
Old Apr 26, 2003 | 10:07 AM
kyxplorer's Avatar
How much can you shave the head and still use 93 octane fuel? My head is currently planed 0.010" and i was wondering if i could go more, still use 93 oc. fuel and see a difference? Also, i finally got my front sway bar done and mounted - made a big difference when running TT's. thanks
hunt
Old Apr 26, 2003 | 10:08 AM
I think the limit for 93 is .020".
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
