scrambler swingarm
Old Mar 1, 2002 | 08:48 PM
harescrambler's Avatar
looking to shed pounds off the scrammbled eggs does any one know of a company that makes the same length swingarm but lighter version
Old Mar 1, 2002 | 11:09 PM
Quadfather's Avatar
I think HotSeat sells one.
Old Mar 2, 2002 | 01:12 AM
TXredneck's Avatar
Check with Rick @ www.rittercycle.com,call him it would be the best thing to do.He sells a lot of thing that are not listed on his web.And he can give you some go ideas.
Good Luck
96 400explorer
99 500scram.
01 250ex
99 250recon
Old Mar 2, 2002 | 01:59 AM
AZ400L's Avatar
Rick doesn't do swingarms. HSP can hook you up with any size you need. Very good quality too, at least mine is.
Old Mar 2, 2002 | 03:50 AM
SandShack's Avatar
If your Looking to shave a few pound.
Replace
Pipe & silencer ( the stock silencer is 9 lbs)
Tires I lost 5 lbs of each front and 6lbs of each rear.
Remove the sprocket guard that gomes on the bike. Its steel and weight 4lbs. add a swing arm skid plate.
Relpacind rear tires and removing the sprocket guard will remove at lest 16lbs of spin weight. (that 16lbs less weight to turn) made my polars sit up and dance.
Old Mar 2, 2002 | 11:08 AM
Ronnnnn's Avatar
When I cut off the floor boards and replaced them with ac pro peg nerfs I lost a bunch of weight, havent weighed the boards and mounts yet but they were heavy.
Old Mar 3, 2002 | 03:51 AM
modquad's Avatar
Harescrambler,
If you are planning any future engine mods, I would try a least the +2.5 stretched Hot Seat swingarm. Still lighter than stock (est 6-8lbs) and it will increase your stability and keep your front down.
just my 2 cents.
Ken
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Nosparkpolaris
Sep 20, 2015 04:21 PM
