scrambler swingarm
Check with Rick @ www.rittercycle.com,call him it would be the best thing to do.He sells a lot of thing that are not listed on his web.And he can give you some go ideas.
Good Luck
96 400explorer
99 500scram.
01 250ex
99 250recon
Good Luck
96 400explorer
99 500scram.
01 250ex
99 250recon
If your Looking to shave a few pound.
Replace
Pipe & silencer ( the stock silencer is 9 lbs)
Tires I lost 5 lbs of each front and 6lbs of each rear.
Remove the sprocket guard that gomes on the bike. Its steel and weight 4lbs. add a swing arm skid plate.
Relpacind rear tires and removing the sprocket guard will remove at lest 16lbs of spin weight. (that 16lbs less weight to turn) made my polars sit up and dance.
Replace
Harescrambler,
If you are planning any future engine mods, I would try a least the +2.5 stretched Hot Seat swingarm. Still lighter than stock (est 6-8lbs) and it will increase your stability and keep your front down.
just my 2 cents.
Ken
just my 2 cents.
Ken
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
