Has any who owns a 4wd Honda had any problems with front differential?
Old Mar 4, 2002 | 05:30 PM
hogmaster's Avatar
The more I read into this problem and research it on many A.T.V. sites, I realize it is a very costley problem if not caught. It seems that on all honda 4wd models, they have been prone to destroying the front differential due to inner bolts coming loose. I am in the middle of taking mine apart so that I will have peace of mind knowing that there is locktite on the bolts. Just wanted to know how you other 4wd guys feel.
Hogmaster
Old Mar 4, 2002 | 06:05 PM
thenewfiebullet's Avatar
I've never had a problem with a quad that I owned, but on a 400 Forman we had at work we had a problem with the half axel coming out of the differential.
You're probably right about the cost. I can't recall exactly what it cost to have it fixed, but I remember it was alot.
Old Mar 9, 2002 | 03:13 AM
Elrancho's Avatar
I don't know what to call a 'lot' like the dirty howie's trax lock kits contain new front diffs among other major assemblys all wrapped up for 400$, that's nopt too much to ask for the front diff alone IMO.
Old Mar 9, 2002 | 10:09 AM
hogmaster's Avatar
I still cant belive that dirtyhowies sends you a brand new diff. with its trax-lok conversion. If you go to partsfish.com and look up the Rancher front final gear assy., the amount of $ for just the inners (not the outter diff case) runs over $500.00. So if they are giving you the complete kit with diff,driveshaft,and electrical components for $350.00, I am going to be extremly skeptical. I want one as soon as possible but I dont want to buy crap either. I am waiting for highlifters and I heard Warn supposedly has one but havent seen anything on it yet.
Old Mar 9, 2002 | 11:06 AM
RubiconMan500's Avatar
My front wheels make a grinding sound when i turn to the left or right think that is a differintial prob?
Old Mar 9, 2002 | 12:11 PM
Elrancho's Avatar
Maybe because general repair parts ( for say if you needed new diff guts ) are marked up well over 100%. ATV's are BIG profit, not even close to at "cost of production"(like economy cars), parts and service are even bigger profit, and something the dealers/distributors can participate in the gouging for parts.
The honda front diff is worth in my breakdown- precision cast and machined housing 50$, pinion 15$, ring gear 20$, high grade bearings 40$, there face plates at about 15$ ( since they have been using a universal, it'd be higher if they used multiple models ) and the followers in the diff $24 for the lot of them, and the shell that connects the followers to the ring gear, a broached steel part 20$. Assembly and tuning of this group at about 20$. IMO that totals about 204$ for the actual cost of the diff and to pay everyone in line at 20$ an hour. Everything else would be directly to corporate profit, covering R&D(they didn't fall off a log and come up with the API diff design) and distributor profit.
Old Mar 9, 2002 | 02:05 PM
BigRed450's Avatar
Check the price at Service Honda for a complete front diff. It is much cheaper then buying the parts. Another example: The whole front knuckle assembly which includes wheel bearing inner and outer seals and lower ball joint is not much more then the cost of the bearing alone.
neilbedwell
Nov 10, 2018 11:02 AM
Jake55
Jun 29, 2015 06:43 AM
'86 TRX125
Jun 6, 2015 07:43 PM
Biggieshortie89
May 26, 2015 08:01 AM
lovinhonda
Jan 25, 2000 09:17 PM
