New Cylinder question, How do you install new cylinder studs? Or do they come in the new cylinder?
Old Mar 13, 2002 | 08:01 PM
shockwave's Avatar
When you buy a new cylinder from honda does it come with the studs in it? How do you properly install them like the factory did, if not?
Old Mar 13, 2002 | 10:24 PM
KNOWSALOT's Avatar
The Facility
The new cylinder will not have new studs installed. You will have to use your old ones. The studs are torgued from the factory using a stud remover/installer, but you can use two nuts threaded against each other to install or remove them. You can do this and still torque them to Honda specs. , but the reading may be off a bit since you will be tightening them using a different method than factory. But it will be close enough.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Polarisman1123
Aug 3, 2015 02:08 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
