NEED HELP FAST......REASSEMBLING CLUTCH ON RAPTOR!!!
Old Mar 16, 2002 | 04:11 PM
MEAN1's Avatar
I took my clutch apart and I'm in the process of reassembling. I have the clutch disc's in and the clutch booss on with the springs tightened down to 5 ft/lbs. How come I can still move the clutch discs back and forth. there is about a 1/4" gap between the last clutch disc and clutch boss. I did not pay any attention to this when I removed it. Does anyone know if this is correct??
Thanks
Old Mar 16, 2002 | 04:34 PM
rraptorr13's Avatar
I would go and purchase a shop manuel.
Old Mar 16, 2002 | 05:11 PM
wshrdskin's Avatar
When you installed the pressure plate onto the clutch boss there is a punch mark on the pressure plate, align it with the punch mark on the clutch boss. This and make sure you have the proper amount of friction plates and clutch plates installed in the right order. I don't believe there should be any movement of disks until the clutch is engaged.
Old Mar 16, 2002 | 07:13 PM
derbyking's Avatar
did you put the spacer ring back in?
Old Mar 17, 2002 | 02:43 AM
MEAN1's Avatar
THANKS!!!!
I do have a manual. I over looked the arrow on the clutch boss. I went back and tore it apart for the 5th time and line the marks up a BAM...there it was PERFECT
Once again thanks for the info.
Old Mar 17, 2002 | 11:47 AM
660bigdaddy's Avatar
where do i get a shop manual and how much?
Old Mar 17, 2002 | 12:12 PM
wshrdskin's Avatar
Any Yamaha dealer can order one for you. I got mine from Alba they had it in stock.
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
