changing the drive belt
Old Mar 19, 2002 | 10:53 AM
ronnieH's Avatar
i am changing the drive belt on my 2000 prairie 400 4x4. I have taken the belt cover off and removed the old belt and installed the new belt. Is this all that I need to do other than put it back together???
All help is greatly appreciated
Thanks
Ronnie
Old Mar 19, 2002 | 01:43 PM
nyroc's Avatar
If you took the driven pulley off, you should have cleaned and regreased it. I don't have a book for the 400 so I don't think you really have to do this if you did not take it off. There is other stuff in my 650 manual to check on the drive pulley, but I do not believe you have to check these things unless you are experiencing problems other than a worn out belt.
Just check to make sure the belt deflection is right and you are good to go. for the 650, push it down with 13lb force, and it should only sag .87 to 1.06 inches. If it sags too much, you remove shim thickness from the shims inside the driven pulley.
My brother's 400 has signs of a loose belt. I will have to do this on his quad soon.
Old Mar 19, 2002 | 04:27 PM
ronnieH's Avatar
no, i didn't remove any of the pulleys, just pulled the belt off and slipped the new one on there. now i am going to figure out how to snorkel the belt housing, it was full of dirt and the rear snorkel was totally clogged with dried mud
Old Mar 19, 2002 | 04:50 PM
nyroc's Avatar
Ya know, I wish these quads were made in a way that you could easily slip on some kind of snorkel tubes in case you see a real deep stream. You would just get some the tubes out and clamp them on, then when you are past the stream you just take them off again.
Old Mar 19, 2002 | 08:41 PM
tom18801's Avatar
what you can do with you cluth snorkel is silicone a peanut butter jar lid onto the hole on the cover and just put a pinhole in it veary little or know water will get in
Old Mar 19, 2002 | 10:04 PM
BigBuck's Avatar
How often do you change/check your belt? I have seen them go 5 or 6 years with out even looking at them.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 20, 2002 | 10:53 AM
ronnieH's Avatar
honestly we wouldn't have checked the belt if the housing had not filled up with water. i believe it to be one of those if it is not broke don't fix it
Cummins Driver
Sep 11, 2019 01:22 PM
cornermike
Aug 10, 2016 06:47 AM
toonces
Jul 31, 2015 09:27 AM
ghost civic
Jul 27, 2015 03:15 AM
trouttracker
Jul 20, 2015 11:54 AM
