Biggest Tire Possible W/O Lift or Rubbing
Old Mar 22, 2002 | 01:57 AM
Yarddog's Avatar
Guy's I know someone out there has experimented to know what the biggest tire I can run Front and Back of my 95' Sportsman. I'm wanting Gators without question, I just put some on the rear of my boy's Recon and these tires are awesome. I currently have stock 25x11x10 on rear and 25x8x12 on front and i would like to step up a size if possible, but I'm not sure about the front. Any experience with this is appreciated. By the way, I want to stay with my stock Wheels also. Thanks in advance. Yarddog.
Old Mar 22, 2002 | 07:58 PM
GE4x4's Avatar
26" tires will be the biggest you will be able to put on without rubbing. I have 26" Mudrunners, and the only time they rub is on a hard corner. This rubbing is mostly due to the winch and bumper. Mudrunners also run in the stock size rims.
Old Mar 22, 2002 | 09:52 PM
ftwflh's Avatar
I went with the stock size of Gators and i am pleased with them.Anytime you put a larger size of tire on a quad it puts more strain on driveline and suspension parts.
Old Mar 22, 2002 | 09:53 PM
ftwflh's Avatar
I forgot you do need a 12in wide tire in the rear
Old Mar 23, 2002 | 06:38 AM
filthyhabit's Avatar
i have a 01 500 ho and have 27x10 on the front and 27x12 on the rear and as long as i keep them inflated there is no rubbing looks tough as hell to
Old Mar 27, 2002 | 10:43 AM
pflueeb's Avatar
yeah well I put mudrunners on mine and the left side has rubbed the outer tie rod end raw!
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
