Does your Raptor start in any gear???
I have a 2001 Raptor, it only starts in nuetral. My freinds will start in any forward gear with the clutch pulled in. I wonder what would cause mine not to??? It is a real pain sometimes, can anyone help??
Sounds like the switch to your clutch cable is mulfunctioning. Did you remove the factory clutch perch and/or emergency brake?
I can give you a workaround to your problem but it also means that your quad will start in gear even if you don't pull the clutch lever in.
/NotuRaptor
/NotuRaptor
follow the two electrical harnesses behind the radiator. there you will find another spot to disconnect the two harnesses. One is a fitting. just unplug and fill connection with electrical grease. the other harness is actually two wires. unplug them. then plug the opposite ends into each other.
<< follow the two electrical harnesses behind the radiator. there you will find another spot to disconnect the two harnesses. One is a fitting. just unplug and fill connection with electrical grease. the other harness is actually two wires. unplug them. then plug the opposite ends into each other. >>
I second these steps.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
