Does your Raptor start in any gear???
Old Mar 22, 2002 | 09:52 AM
KCRaptor's Avatar
I have a 2001 Raptor, it only starts in nuetral. My freinds will start in any forward gear with the clutch pulled in. I wonder what would cause mine not to??? It is a real pain sometimes, can anyone help??
Old Mar 22, 2002 | 11:02 AM
NotuRaptor2's Avatar
Sounds like the switch to your clutch cable is mulfunctioning. Did you remove the factory clutch perch and/or emergency brake?
I can give you a workaround to your problem but it also means that your quad will start in gear even if you don't pull the clutch lever in.
/NotuRaptor
Old Mar 22, 2002 | 12:48 PM
RW660's Avatar
Please tell me how!!! I have removed the factory clutch assembly and can only start in neutral. I hate it!!!
Old Mar 22, 2002 | 06:00 PM
kuz28's Avatar
follow the two electrical harnesses behind the radiator. there you will find another spot to disconnect the two harnesses. One is a fitting. just unplug and fill connection with electrical grease. the other harness is actually two wires. unplug them. then plug the opposite ends into each other.
Old Mar 22, 2002 | 06:32 PM
velocityraptor's Avatar
<< follow the two electrical harnesses behind the radiator. there you will find another spot to disconnect the two harnesses. One is a fitting. just unplug and fill connection with electrical grease. the other harness is actually two wires. unplug them. then plug the opposite ends into each other. >>
I second these steps.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
