Lt250r carb
Old Mar 26, 2002 | 06:39 PM
suzukiboom's Avatar
I just bought a 36mm carb for my lt250r and it bogs,(i think its running to rich) really bad does any one know what size jets to put carb,please help or can you tell me what size jets you have in yours if you have one.
Old Mar 31, 2002 | 11:41 AM
ZillaDaddy409's Avatar
I hope I can help.... does it idle???when revving it up does it bogg then or when getting to top speed???Say it's idling good,then you try it out does it go ba-wahhhh sluggish when snapping the throttle open???,or does it blubber and don't clean out at top-end??.....Zilla
Old Mar 31, 2002 | 12:42 PM
truckracer's Avatar
<< I hope I can help.... does it idle???when revving it up does it bogg then or when getting to top speed???Say it's idling good,then you try it out does it go ba-wahhhh sluggish when snapping the throttle open???,or does it blubber and don't clean out at top-end??.....Zilla >>
Hey Zilla, I have a Quadzilla (1989) that I have some jetting qustions about. It has been ported &amp; polished, carb bored to 39.5, FMF Fatty, holes in airbox lid. Stock bore. All this done by previous owner. Main jet is currently a 350 which is stock...... I really haven't rode the quad as I just had the engine rebuilt. Does this jetting sound close to you?
Denny
Old Mar 31, 2002 | 11:55 PM
Trixterboy's Avatar
Suzukiboom I just put a 27.5 pilot and a 300 main and needle in the second slot from the top. Seemed to work good didn't load up and went thru powerband good!
Old Apr 1, 2002 | 01:11 PM
Mxracer98's Avatar
ZillaDaddy409,yeah it does everything you said,the main jet is a 160 so i'm thinking of putting in 2 sizes smaller,would this help?
Old Apr 1, 2002 | 01:34 PM
[img]i/expressions/face-icon-small-shocked.gif[/img] OK.....When you first get going (after warmup) and your putting around in 2nd gear and you snap the throttle wide open does it go baaaa wahhhh if so the slow speed of the carb need's to be adjusted....too lean....If your putting along and it's snappy in second gear and you snap the throttle open to get top speed and it blubber's and won't clean out....then your too rich...also check the air/fuel mixture screw located on the side of the carb....(not the idle screw)also listen to the motor after you have made some adjustment's....a too lean condition will not rev out instead it will kind of flat line out and you will feel the pull go away from the motor.....check the color of the plug.....white mean's toooooo lean,light brown is good,clean no color perfect,black too rich......I hope I've helped...Zilla
Old Apr 1, 2002 | 07:07 PM
suzukiboom's Avatar
Ok i know that its too rich,cause it has a little power in the lower rpms,or if you slowly give it gas it'll rev out to a certain point,but when you give it alot of gas it starts too bog and spudder out, the main jet is a 160 would it help to go one or two sizes smaller?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
