backfiring
Old Mar 26, 2002 | 11:47 PM
calgaryquadguy's Avatar
I have a 1997 polaris sportsman 500. Does not have the engine braking system. Runs great but when going down hill and I let off the gas it backfires, it only backfires under these conditions. Anyone else out there have this problem with their machine?
Old Mar 27, 2002 | 12:17 AM
dcroc's Avatar
I have a 96 with no backfiring, might try cleaning the carbon out of the muffler, just pull the plug and put your hand (with glove or rag)over the outlet and start it up and blow it out, might tap around on it this helps.
Old Mar 27, 2002 | 12:36 AM
thanks for the advice, I will give this a try.
Old Mar 27, 2002 | 01:26 AM
dcroc's Avatar
Another thing it might be is a intake leak, check the carb. Might be loose.
Old Mar 27, 2002 | 02:11 AM
BarelyLegal's Avatar
Is it stock? You might be lean.
Old Mar 27, 2002 | 04:19 AM
polardogg's Avatar
Did you check throttle cable adjustment? If it has too much freeplay the ETC will cause the bike to backfire.
Old Mar 27, 2002 | 03:25 PM
samclow's Avatar
POLARDOGG,hit the nail on the head about the ETC switch being out of adjustment this will cause the machine to backfire every time when you let off the gas and the machine is coasting to a dead stop.
Old Mar 27, 2002 | 08:14 PM
all excellent suggestions guys, thanks for all the help, sounds like the ETC switch could be the culprit, I will work my way through this list.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
