what mod for a warrior ?
Old Mar 29, 2002 | 05:50 PM
juststout's Avatar
hi i got a 02 warrior i would like to know what mod i should get i have 100 $ to spend please help
thanks. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 30, 2002 | 11:50 AM
A2000's Avatar
GET a Pro Design Pro Flow air filter/adapter kit. The stock system is a joke and will leak dirt into your engine in no time. The Pro Flow seals much better and flows more air too. For a hundred bucks, ANYONE on this forum or in any magazine that owns a Warrior or Banshee will tell you to do this. Trust me.
Old Mar 31, 2002 | 12:47 PM
truckracer's Avatar
I agree on the air fliter suggestion. Also you might want to change the front sprocket. 14 tooth is the one I believe (you want one tooth more than stock for higher speeds). Other than that I wouldn't change a thing!
Old Mar 31, 2002 | 02:23 PM
juststout's Avatar
well if i go to a 14 toth sprocket what will that do?
Old Apr 6, 2002 | 12:27 AM
Warrior400boy's Avatar
when you do get more money, get some kinda pipe, bore it out and put a performance piston in it, diff carb many more things too
Old Apr 6, 2002 | 03:11 PM
inspiron's Avatar
I agree with a2000, the pro flow was my first mod on my 2000 banshee. After that modify your air box lid and add a pipe. THis will greatly increase your power output.(don't forget to rejet) Then do some chassis mods like Holeshot tires all the way around, then look into some a arms then shocks, axle and most definitly aloy handle bars. After you chassis is up the par then look into some more extensive motor mods like maybe a bore kit with higher compression, A high lift cam and a port job on your head. New carb and beef up your clutch and Beat the Crap out of every HONDA you can find!!!!!
inspiron
Lonestar/Duncan Banshee ...never been beat by ANY Honda
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
