are there fuses on a 2000 sportsman 500?
I'm willing to bet it's your voltage regulator
You have a voltage regulator mounted in front of your radiator frame,it's on the left side(if your sitting on the bike).Best way to find it is...on your left front fender light,theres a wireing harness that plugs into the light,follow the wire(from the light) under the fender ,it goes right to the voltage regulator(about 8-10inches away from the light)It's mounted on the radiator brush guard
Its a thin 3x3inch black box
with 4 wires comeing out of it
Check those wires,make sure thier not broken or disconnected.
well same thing happened to me today so i got bored and i started looking at wires and it turns out where to wires go down in the pood they go between to metal prongs of whatever and it cut the power clean in half there is like a regulator or whatever and about 6 brown wires go into it its one of them hope that helps
