are there fuses on a 2000 sportsman 500?
Old Mar 30, 2002 | 08:39 PM
chevsun's Avatar
My AWD stopped working. No indicator light or power in the switch. Are there fuses that I just cannot find?Also there is no sputter of the motor to override when going fast in reverse.
Old Mar 31, 2002 | 04:19 PM
philmacrackin's Avatar
Try fiddling with your shift lever. It may have some slack or be misadjusted.
Old Mar 31, 2002 | 05:04 PM
chevsun's Avatar
Thanks I'll give that a shot. The speedo doesnt work or show mileage either.
Old Mar 31, 2002 | 10:19 PM
eb's Avatar
eb
Try messing with your ignition.Mine was doing that and all it was,was the key kept turning back just enough that the engine still ran but the AWD had no power.
Old Apr 1, 2002 | 07:47 AM
500DUSE's Avatar
I'm willing to bet it's your voltage regulator
You have a voltage regulator mounted in front of your radiator frame,it's on the left side(if your sitting on the bike).Best way to find it is...on your left front fender light,theres a wireing harness that plugs into the light,follow the wire(from the light) under the fender ,it goes right to the voltage regulator(about 8-10inches away from the light)It's mounted on the radiator brush guard
Its a thin 3x3inch black box
with 4 wires comeing out of it
Check those wires,make sure thier not broken or disconnected.
Old Apr 1, 2002 | 08:29 AM
ftwflh's Avatar
it could be as simple as a blowen light bulb in the AWD.It has to light up to complete the circut.
Old Apr 1, 2002 | 09:39 PM
MagNumMan696's Avatar
well same thing happened to me today so i got bored and i started looking at wires and it turns out where to wires go down in the pood they go between to metal prongs of whatever and it cut the power clean in half there is like a regulator or whatever and about 6 brown wires go into it its one of them hope that helps
Old Apr 2, 2002 | 06:15 PM
500DUSE's Avatar
Well??????????
velcro7279
Aug 24, 2015 01:15 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Unzzy66
Jul 11, 2015 10:01 PM
