left front hud wont engage
Old Mar 31, 2002 | 10:00 PM
ftwflh's Avatar
MY front left hud wont engage give me what could all could be wrong with it.I know i have a seal leaking but it does it when it is full of oil.And what kind of a job am I getting into?
Old Mar 31, 2002 | 10:08 PM
Farmr123's Avatar
First off, if the hub runs dry, you almost always have some sort of 4wd problems.
I recommend first & foremost to replace the leaking seal. You can download a parts listing off the Polaris website. If they don't list your model, don't worry too much, as almost any 4wd will have a front hub very similar, if not the same as you do. The most important thing to watch when re-assembling is to be sure the 3 tabs on the armature plate fit into the notches in the hilliard assembly. Once you get it apart, you will see what I mean. If the armature plate looks at all bent or warped, replace it.
On a 1-10 difficulty scale I rank it about a 5. An inch pound torque wrench is a big help in setting the bearings, but not absolutely needed.
Old Apr 1, 2002 | 08:56 PM
ftwflh's Avatar
I found the problem.It was EXPENSIVE stripped the splines off the cv joint-decenagrated the clutch so I had to buy a new hub and all the guts.That wasnt all of it when i took the nut off the ball joint and the tie rod the threads pulled off too.Thats what you call BAD LUCK[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 1, 2002 | 11:10 PM
WhoDatInDaMud's Avatar
These notes might help.
I thought I posted this before but I don't see it. Oh well.
First I recommend an appropriate shop manual for your quad. – Follow those instructions.
A few tips in removing and reinstalling the front hubs - Put jack stands under the front struts to hold the bike up . Have the weight of the bike on the jack stands under the struts. Without doing this when you remove the axle nut you will likely over extend the struts and pull the axle CV joint apart. Usually followed by numerous expletives and a trip to the shop to purchase a new CV boot ring because after two hours of unsuccessful attempts to blindly correct the problem inside the boot you succumb to taking it apart to re-assemble the CV joint.
Next - zero sand\contaminants are allowed in the hub\clutch\bearings. A parts washer and pressurized air to blow everything off is highly recommended. A $39 parts washer can save hundreds. I blow WD40 through the strut and inside bearings liberally and then air blow the axle / strut area as best that can be done.
Make sure the armature plate is not bent – even a little bit, and when reassembling ensure that the armature plate is flat against the coil and flat against the roll cage with the tabs correctly engaged in the roll cage. Flat means that the plate comes in contact with both the outer and inner coil lips – as checked at 120 degree angles around the coil. Not having the armature plate in the correct place is the other area most of us mess up and we damage both the armature plate and the magnet coil gap when we torque the axle nut which makes the clutches either not release or not engage for 4WD – there go providing the opportunity to do it all over again. Not having the correct coil gap prevents the energized coil from tightly "grabing" the armature plate slotted to the the roll cage and it not receiving enough resistance to torque around the cam and extend the roll pins – which is the goal to engage the hub to the axle.
Oh – keep in mind that you will have to lift the rear of the bike to facilitate rotating the drive train to assist in properly seating the front axle inner bearings into position.
Proper torque of the axel nut is required – first to 100 inch pounds, then back off and re-torque to 75 + whatever it takes to get to the nearest hole for the cotter pin.
Don’t forget to add fluid. Ford ATF or Polaris Hub Oil.
Good luck
Old Apr 2, 2002 | 08:07 PM
ftwflh's Avatar
Had to replace it all cost over $500 in parts.Da#$ my luck.[img]i/expressions/face-icon-small-sad.gif[/img]
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
coolguy420
Jul 10, 2015 01:17 AM
jettman
Jul 6, 2015 12:16 PM
traumajunkie
Jul 5, 2015 03:03 PM
