Winter oil weight
Old Nov 21, 1999 | 09:04 PM
Mike Frey's Avatar
I have a '99 400EX and I am getting ready for winter here in Minnesota. What oil weight should I run? The manual says SAE 5W for temps 50 to about zero. I have been using GN4 10W-40 with no problems, and I've been told that 10W-40 would be fine once the engine is warm. Should I switch down to 5W, or stay at GN4 10W-40? The lowest temp I would ride would probably be -10 degrees.
Old Nov 21, 1999 | 11:37 PM
JRM's Avatar
JRM
Doesnt matter how cold it is when you ride. It is starting temp that counts.. If you are starting it at anything below 0 I would get a full snythtic 5W or even 0W30.
Joe
Old Nov 21, 1999 | 11:39 PM
JRM's Avatar
JRM
after thinking even more on this, If I was you and wanted to ride at -0 temps I would pore Amsoil 0W30 in it. Even if it gets warm for a week or two the snythtic will be as thin as lamp oil but will still protect prefectly
Old Nov 22, 1999 | 01:06 AM
rooster's Avatar
You should run an oil that's made for off road vehicles, don't use an automotive oil. Also, I don't know if sythetic would be good in your case because of your manual clutch. Synthetic oils tend to be slippier than regular ones, so you might have some clutch slippage. I use Honda GN4 10W 40 in the winter.
Old Nov 22, 1999 | 02:08 PM
hot_shoe_cv's Avatar
you might want to look into a dipstick crank case heater that plugs into ac.It will keep your 10/40 oil at a nominal viscosity unti you start your quad.J.C.Whitney catalog shows a magnetic mount oil pan heater that can be placed on any point of the engine that will heat up to 250 degrees. About $25
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
r1pilot83
Sep 27, 2015 07:38 PM
byronman
Sep 6, 2015 06:34 PM
