HELP WITH JETTING & ADDING PIPE
Old Apr 5, 2002 | 02:15 AM
BiscuitBoy's Avatar
I live in Chicago, I just added a 02 Raptor to my toy collection. The problem is I ordered a Big Gun exhaust and I am not sure how to rejet it. Does it need to be done for sure after I add the pipe? Also does it really help to cut holes in the top of the air box. I am sure this like my other toys can get to be excessive in terms of cost. Right now I just want a few mods to make it a little quicker and a little easier to ride(ie. maybe a lowering kit, gets a little tricky in short turns)
Any help or suggestions would be a great help
Old Apr 5, 2002 | 02:39 AM
THEMOOSE's Avatar
Yes you will need to rejet. I would recomend a Dynojet stage 2 kit their recomendations are real close & the diffrent design jets & needles add more power themselves (The K&N kit is the same thing & is usually cheaper). To jet, get a Yamaha factory service manual (About $50 & $15 for the 02 update) follow the instructions & it's not hard, I did mine in about 2hrs the first time now it takes less than an hour. I put 5-1" holes in mine with univent filters in it. But there are a lot of diffrent opinions on this but mine is leave the lid on.
A lowering kit is not a good idean if you jump. A wider axle or even axle spacers are a better Idea.
You should also think about replacing your stock filter setup with a Pro Flow adaptor & filter. It's a much better design.
Since this is your first post you may want to lookaround & do some searches, this is a quick way to see what has been said on your topic before.
Enjoy your Raptor & ride safe!
Old Apr 6, 2002 | 09:42 AM
guardog's Avatar
I put the "e" series on my raptor, took off the snorkle (big difference) and went up two sizes on my jetting. I also put in the K&N filter with outerwear. I'm not sure if I really like the way the K&N just lays in there. If I could do it over, I would probably go with the pro-flow like "Moose" suggested. But everything works great. You do not need to spend the extra money on a head pipe. The stocky works just fine. I would not recommend cutting into the air box either, just take off the snorkle
mrtidy
Feb 3, 2016 05:00 PM
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
WilliamBos
Sep 22, 2015 04:07 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
