primary spring
Old Apr 11, 2002 | 10:23 PM
99sport's Avatar
I just got finished putting on an orange aftermarket primary spring and air box mod--ha ha so simple!Talk about cat walking!It use to be real hard to get my front end up on my 99 sport.Now it is VERY easy to get it up and hold it.I think I lost alot of top end though.I have not rode it alot but it doesnt pull as hard going down the dirt road like it use to.But boy does it pull hard from a dead stop.Does this sound normal for this spring?I dont want to loose any top end.Do I need to change to a green?Any help would be greatly appreciated. THANKS p s-- my rpms are alot higher now----could I be out of my torgue range for the motor?I have boyesen power reeds,reed valve spacer,K&N filter,black secondary spring from HOT SEAT,orange primary from RCR and air box mod from RCR.THANKS for the help.
Old Apr 11, 2002 | 10:45 PM
biggin's Avatar
Yes its gonna pull hard from a dead stop because the engagement is so high. My 98 sport engagement was 2800rpm. that high of an engagement also causes tremendous amounts of belt slippage and could possobly groove the clutch surface. Save some trouble, get a clutct kit. Your top speed is gonna suffer becuase of the wasted rpm(about 2800)and because the stock wieghts are not heavy enough to push the orange spring to fully engage the clutch. I went the same path you are going. Had the orange spring with rcr top end stage 1 kit. get a hole kit complementary to your engine. (40.00$ a hour advice from my polaris mechanic). runnin 58g wieght and red primary and violet secondary from hpd trail pipe/ported clutch kit. hope this helped you.
98 sport 400L
rcr stage 1
v force reed cage
hpd clutched
Old Apr 11, 2002 | 11:59 PM
AZ400L's Avatar
The misconception with kits is that they resolve everybody's problems, when in fact they DO NOT work for everybody, contrary to popular belief. Most do require some slight tweaking.
I suggest you drop down to a 34T rear, swap in a HPD violet secondary spring, supersport button kit and an aftermarket helix, something like 42/38, maybe 42/36, and set the spring to 2/2. The new HPD kevlar belt will help with the belt slippage issue, as well as provide much better wear and power transfer than the OE units.
I ran the orange for over a year and think it is a good spring for a piped (no motor work) bike, but you will have to tune the reast of the CVT to work with it, not against it.
Think it's easy to wheelie now, try a race modded 400, lightened to 375LBS with an angagement aroung 4500RPM's :0
Old Apr 12, 2002 | 12:25 AM
RickRitter's Avatar
Just a note . I use two different orange springs , one a aftermarket orange , and the other , polaris orange .
We always knew we couldn't mix apples with oranges , now we can't even mix up oranges with oranges .
Old Apr 12, 2002 | 03:30 AM
BarelyLegal's Avatar
I used the aftermarket orange on my magnum 325 and it was a bit too much. It's out now and I'm happier. The green spring in my 500 is perfect. I might get one for the 325 as well.
Old Apr 12, 2002 | 12:12 PM
RickRitter's Avatar
Note :
After market orange engages higher than polaris green . After market orange shifts sooner than polaris green . Top speed on a 2002 400 sportsman (4 stroke) is 2 mph better with aftermarket orange .
Old Apr 12, 2002 | 01:13 PM
Does Polaris green lose or gain top end? Can I put one in my Magnum?
What setup can I go with to gain about 3-4 mph but not engage too high or lose torque on my 500 Scrambler. Sounds like the rear spring does most of that work.
Thanks
Ridgerunner665
Sep 15, 2015 01:20 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
