Installing Winch on 650
Old Apr 13, 2002 | 12:56 AM
Cose's Avatar
I would like to know if there are any problems that I may encounter in installing a Ramsey ATV Wireless Remote winch that anyone has run into? Any info regarding same is appreciated. Im gonna tackle the job this weekend hpefully. Thanks....
Old Apr 13, 2002 | 10:37 PM
monteSS's Avatar
No it wasn't to bad to put in I put the relay under the front plastic the wires aren't lon enought to mount the relays in the back just make sure u have a good ground on the remote box I have to pull the front off and redo the ground it isn't working right.
Old Apr 14, 2002 | 08:40 PM
Cose's Avatar
Thanks for the comeback MonteSS. I started the installation and thought I was doing pretty good until I tried to mount the solenoid on the tube frame as stated to do on the directions. I tried to mount it on the vertical tube right behind the radiator. The tube clamps that were provided just barely fit around the tube and the screws that were supplied are not long enough to fasten it together. Either Im doing something wrong or I got the wrong parts. Where did you attach your solenoid? Maybe Im putting mine in the wrong place. Also did you have any trouble finding the red ignition wire? I haven't looked yet but want to make sure I get the right one. Any info you could give me in this matter will greatly be appreciated. Thanks Again & Good riding
Old Apr 15, 2002 | 06:07 AM
monteSS's Avatar
I couldn't get mine to mount at any of the locations you said either. I ended up mounting it on the plastic over the radiator and between the hood. It worked real well it has a slight bump in the black plastic over the radiator to allow for the wires and you don't have to worry about it shorting to any metal. As for the ingnition wire I didn't run it to that incase I got stuck and it shut down on me and I couldn't get it started agian and didn't want any extra power drain so I wired it directly to the battery with a 3 amp fuse in line with it. If you want I will e-mail you picks as soon as I get the film back.
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
