Moisture in 01 400ex carb, throttle sticking
Old Apr 22, 2002 | 10:19 AM
mudevil's Avatar
My carb in my 400 ex is getting moisture where the piston goes up and down causing the throttle to stick. I am debating on replacing it with a new carb but wanted to see if anyone has had this problem before and how they corrected it. My freind also has an 02 400ex that is doing the same thing. Thanks in advance for any help.
Old Apr 22, 2002 | 08:42 PM
tprender's Avatar
Check the o=ring on the top and make sure that it is installed correctly. Is the bolt tight around the cable going into the plate? How much water are you riding in or thought?
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Jun 2, 2019 07:25 AM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
