Winch Problem
Old Apr 25, 2002 | 03:52 PM
Cokerg's Avatar
I had this posted in another section, I was told that this would be a good place to post my question as a lot of you have info on the subject:
I installed my Warn 2000 onto my Vinson today. I did not hook up the solenoid, because I didn't have the one-way diode to prevent feedback. I want to make sure I installed the thing right. I hooked the negative on with switch to the neg. battery, positive switch to positive battery. I then hooked #1 on switch to #1 on winch and #2 on switch to #2 on winch.
Do I need any type of circuit breaker installed?
Also, as I read the owner's manual I came to "stretching the wire rope". It says to "spool out the entire wire rope length leaving 5 wraps on the drum, then power in the wire rope under a load of 500lb". Well, apparently I didn't have a 500lb load and the cable did not pull back correctly. I hope I didn't damage the cable, I'm going to have to try and pull the cable back off tomorrow and try again. Any ideas as to what I can pull that weighs 500lb w/o my atv moving?
Man, I'm having a problem getting the wire back on correctly. Do you always have to hand guide the wire as you pull it in?
Thanks in advance for the help.
Old Apr 25, 2002 | 04:13 PM
700guy's Avatar
I am not sure on the wiring without looking at the manual. As far as the spooling of the cable, all you have to do is hook to a stationary object such as a tree or telephone pole. Don't let the power company see you. Apply your brakes firmly as you spool the cable in. Have a friend watch as you spool the cable in to tell you which way you need to turn to guide the cable on evenly.
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
