baffles?
Old Apr 27, 2002 | 07:29 PM
ravenx2069's Avatar
how do you remove the baffles out of a stock 250ex pipe? also will it mess with the power?..
Old Apr 28, 2002 | 09:39 AM
hondaquadrider's Avatar
There are three bolts on the end of your pipe, take them out and your baffle will come right out, i like it that way cause if you want them back in you can just bolt them back in. I had a 250EX here while back and i had my baffle out for six months till i got a pipe for it, I couldnt tell that it changed the power any.
Old Apr 15, 2010 | 04:30 AM
aja72's Avatar
Good explanation & this is perfect method for removing baffle.
Old Apr 15, 2010 | 11:47 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Removing the baffle will allow you to do cleaning and maintenance, but don't run it with out the baffle in place...it won't change the power output one bit, it will sound like crap, and you will just be a nuisance to everyone.
Old Dec 19, 2010 | 01:16 AM
hunterp90's Avatar
i have a 250 ex too and i'm doing the same thing. but im going to jet the carburetor and put a k&n air filter in it and probably buying an exhaust tip. taking the baffle out messes with the air flow. and it does change power a little cause it speeds up all the air in-take and exhaust process
Jason Poulin
Sep 20, 2015 02:49 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Huntingdeer
Aug 23, 2015 12:06 AM
raceware
Jul 30, 2015 06:59 AM
cSchwartz
Jul 12, 2015 07:42 PM
