Removing the ball joint out of a strut????
USE A BLIND HOLE FLANGE PULLER/ OR WELD A BOLT IN THE HOLE WHERE THE BALL JOINT GOES THEN TAKE SOCKET AND SLIDE OVER THE BOLT AND THEN TAKE THE NUT FOR THE BOLT AND SCREW IT ON THE BOLT THEN USE IMPACT WRENCH IT WILL PULL THE BALL JOINT HOUSING
forgot to mention sometimes you can pull with a two jar puller attached to a slide hammer and sometimes you can hook your air hose up to the grease fitting and the remains of the ball joint can be blown out with air, but the best way is using a blind hole flange puller
