Removing the ball joint out of a strut????
Old May 2, 2002 | 09:32 PM
400fnSport's Avatar
I've got my 98 Sport strut which I broke a ball joint in a while ago. I removed the cover and tried to get it out, but couldn't figure it out. So I thought I would ask here before I broke something???
Old May 2, 2002 | 10:08 PM
hodaddy's Avatar
USE A BLIND HOLE FLANGE PULLER/ OR WELD A BOLT IN THE HOLE WHERE THE BALL JOINT GOES THEN TAKE SOCKET AND SLIDE OVER THE BOLT AND THEN TAKE THE NUT FOR THE BOLT AND SCREW IT ON THE BOLT THEN USE IMPACT WRENCH IT WILL PULL THE BALL JOINT HOUSING
Old May 3, 2002 | 07:40 AM
hodaddy's Avatar
forgot to mention sometimes you can pull with a two jar puller attached to a slide hammer and sometimes you can hook your air hose up to the grease fitting and the remains of the ball joint can be blown out with air, but the best way is using a blind hole flange puller
jdunne01
Oct 4, 2015 10:29 AM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
89Lt250r
Sep 7, 2015 07:53 PM
