Just Built Motor having Jetting Problems, need help, please
I have just had my motor rebuilt (2000 model Wolverine)with a 11:1 Piston, Cam, HD Valve Springs, ported and polished head, Mikuni Carb with built in fuel pump running on race fuel 50/50 with pump gas.
The problem is from one third throttle to two third throttle. There is minor bogging and sputtering/coughing as it gets up into the higher RPM's. Once it gets above two third throttle it takes off like a two stroke and pulls hard all the way up through the gears as long as you stay above two-third RPM's.
Thanks for any help or suggestions you have.
JackOReilly
Dec 7, 1999 09:12 AM
