Top Speed On 2002 Big Bear 400 2WD
Old May 13, 2002 | 02:07 AM
FUJIMO's Avatar
I have a 2002 Big Bear 2WD with 18 miles, it sounds like it's going to blow at 35 MPH is that the top speed are is something wrong.
help please
Old May 13, 2002 | 09:45 AM
REDBEAR4x4's Avatar
It's not suggested to run full throttle during the breakin of a new machine. Double check your speedo cable to make sure it is tight common problem from dealer to customer on delivery for some reason. Does it have a high low range? Also do not trust the speedo they are not accurate actually your going slower.
Old May 13, 2002 | 01:45 PM
FUJIMO's Avatar
Thank's sense it is new I didn't want to run it that hard but 35MPH is really slow I will check the cable I can't find a high are low on it.
Old May 13, 2002 | 11:13 PM
Lsnake68I's Avatar
doesn't matter the speed really. it says half throttle an 3/4 throttle. just read te owners manula and it will tell you the proper way to do everything.
Ean
Dec 19, 2022 08:48 AM
Cummins Driver
Sep 11, 2019 01:22 PM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
