blaster jetting
Old May 17, 2002 | 12:00 AM
mikes440ex's Avatar
Picked up a brand new blaster recently. Broke it in some but as I push it harder it won't rev., just sputters and goes flat past 1/3 throttle. Took the air box lid off and it runs like a raped ape. Mechanically everything seems to be OK. Anyone else get a new blaster that runs extremely rich? BTW at sea level and about 60 deg.
Old May 17, 2002 | 03:13 AM
KNOWSALOT's Avatar
The Facility
I've never heard of a need for a jetting change after break-in on any model.
You sure the air filter just doesn't need cleaning?? Did you change fuels or injection oil?? Did you change to pre-mix??
If it isn't the air filter, take it back in to your dealer. Even if it does require jetting, warranty will cover it and all the trial error required to do so.
Old May 17, 2002 | 03:55 AM
redrider707's Avatar
lean is fast but can be BAD your realy hurtin the thing. put the lid on and go down 2 sizes and check it and from ther go down 1 size at a time till you get jeted right
Old May 17, 2002 | 03:59 AM
and you could try dropin the neddle a clip move clip up to lower the neddle. pilot jet close to 1/4 neddle is 1/4 to 3/4 main 3/4 to full .
ReconBayou
Oct 31, 2022 05:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
