AWD system
Old Mar 6, 2000 | 04:58 PM
Jaybee's Avatar
Does the awd system still engage when the handlebar selector not in awd? My wifes 99 Scrambler 500 does. My brothers 98 425 magnum does too. He said that the dealer told him that the will. Anyone know anything about this?
Jaybee
Old Mar 6, 2000 | 05:09 PM
Thor's Avatar
It should not engage. Unless you have a defective switch.
Old Mar 6, 2000 | 05:25 PM
xepathfinder's Avatar
mine never does when it is off it stays off. Must be a faulty switch.
Old Mar 7, 2000 | 06:51 PM
seacow's Avatar
If it's not your switch, then I would say the set up is wrong from the factory, meaning, the armeture plate, coil, "Hillerd" clutch tolerances are off, this is a fine tuned setting that has to be correct, if not you will have unwanted engagment and premature ware. (the clutch thinks the coil is on and is creating a drag on the clutch, thus ingagment occures) The only other thing I can think of is that the spring that holds the rollers into the "relaxed postion" on the clutch is week of streached, this could also give you the simtums you discribe. This is less likely)
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
